The original Florida State University press release by Bill Wellock can be read here.
The designers of solar cells know their creations must contend with a wide range of temperatures and all sorts of weather conditions — conditions that can impact their efficiency and useful lifetime. Florida State University (FSU) Assistant Professor of Chemistry and Biochemistry Lea Nienhaus, and former FSU postdoctoral researcher, now Argonne National Laboratory Assistant Scientist, Sarah Wieghold are helping to understand the fundamental processes in a material known as perovskites, work that could lead to more efficient solar cells that also do a better job of resisting degradation. Using high-brightness x-rays at the U.S. Department of Energy’s Advanced Photon Source (APS), they found that small tweaks to the chemical makeup of the materials as well as the magnitude of the electrical field it is exposed to can greatly affect the overall material stability. Their work was published in the Journal of Materials Chemistry C and the Journal of Applied Physics.
Their research is focused on improving the potential of perovskites, a material with a crystal structure based on positively charged lead ions known as cations and negatively charged halide anions. In a cubic perovskite crystal structure, the octahedra formed by the lead and halide ions are surrounded by additional positively charged cations.
The first perovskite solar cells, which were developed in 2006, had a solar energy power conversion efficiency of about 3%, but cells developed in 2020 have a power conversion efficiency of more than 25%. That rapid increase in efficiency makes them a promising material for further research, but they have drawbacks for commercial viability, such as a tendency to degrade quickly.
“How can we make perovskites more stable under real-world conditions in which they’ll be used?” Nienhaus said. “What is causing the degradation? That’s what we’re trying to understand. Perovskites that don’t degrade quickly could be a valuable tool for obtaining more energy from solar cells.”
Perovskites are a so-called “soft material,” despite the ionic bonds of the crystal lattice that make up their structure. The halides or cations in the material can move through that lattice, which may increase their rate of degradation, resulting in a lack of long-term stability.
In the Journal of Applied Physics paper, they explored the link between voltage and the performance of perovskite materials using synchrotron x-ray scanning tunneling microscopy in ultra-high vacuum at the APS 4-ID-E XTIP beamline, which is operated jointly by the Argonne Center for Nanoscale Materials and the APS X-ray Science Division Microscopy Group. The team also employed conventional scanning tunneling microscopy. This showed that the ion movement in the material changes the underlying electrical response, which will be a critical factor in the photovoltaic performance.
In the Journal of Materials Chemistry C paper, the researchers investigated the combined influence of light and elevated temperature on the performance of mixed-cation mixed-halide perovskites.
They found that adding a small amount of the element cesium to the perovskite film increases the stability of the material under light and elevated temperatures. Adding rubidium, on the other hand, led to worse performance.
“We found that depending on the choice of the cation, two pathways of degradation can be observed in these materials, which we then correlated to a decrease in performance,” said Wieghold, now an assistant scientist at the Center for Nanoscale Materials and the Advanced Photon Source, both Office of Science user facilities at Argonne National Laboratory. “We also showed that the addition of cesium increased the film stability under our testing conditions, which are very promising results.”
They also found that a decrease in film performance for the less stable perovskite mixtures was correlated with the formation of the compound lead bromide/iodide and an increase in electron-phonon interactions. The formation of lead bromide/iodide is due to the unwanted degradation mechanism, which needs to be avoided to achieve long-term stability and performance of these perovskite solar cells.
“Perovskites present a great opportunity for the future of solar cells, and it’s exciting to help move this science forward,” Nienhaus said.
See: Sarah Wieghold1,2, Nozomi Shirato2, Volker Rose2,, and Lea Nienhaus1, “Investigating the effect of electric fields on lead halide perovskites by scanning tunneling microscopy,” J. Appl. Phys. 128, 125303 (2020). DOI: 10.1063/5.0011735
Author affiliations: 1Florida State University, 2Argonne National Laboratory
Correspondence: *[email protected], **[email protected]
S.W. and L.N. gratefully acknowledge Florida State University startup funds. This work was performed in part at the Advanced Photon Source and the Center for Nanoscale Materials, U. S. Department of Energy Office of Science User Facilities, and supported by the U. S. Department of Energy Office of Science under Contract No. DE-AC02-06CH11357.
And
Sarah Wieghold1*, Alexander S. Bieber1, Masoud Mardani1, Theo Siegrist1,2, and Lea Nienhaus1, “Understanding the effect of light and temperature on the optical properties and stability of mixed-ion halide perovskites,” J. Mater. Chem. C 8, 9714 (2020). DOI: 10.1039/D0TC02103B
Author affiliations: 1Florida State University, 2FAMU-FSU College of Engineering,
The authors gratefully acknowledge Florida State University startup funds. Part of the work was carried out at the National High Magnetic Field Laboratory, which is supported by the National Science Foundation under NSF DMR-1644779 and the State of Florida. T. S. acknowledges support by the Department of Defense, Air Force Office of Scientific Research under AFOSR 040702.
